3 members (delky, Hanks custodian, Rich'sToys), 127 guests, and 3 robots.
Topics128,149
Posts1,056,817
Members48,454
I have a S/S tank moved to rear, Disc Brakes added to front, Custom Drive Shaft made, Reinforced the trailing arms on the 62,Powder coated the Frame and Radaitor Support, Powder Sreering with Quick Ratio added, Powder coated Inter Fender Shields and Radiator Support Covers, Hood Latch & Powder the Coil Springs, added 100 Micron Filter to the Fuel Tank Line.
The future add ons will be Ralley Wheels with Beauty Rings,Chevy Hub Caps, Vintage Air conditioning, AM-FM Radio, New Mirrors Org. Chevy type and repair the org. Steering Wheel and Turn Signels. The list goes on and on but it will be in my family for a very long time.
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
I'm a big fan of improved brakes. I have disks on the front and later drums in back, along with a dual master setup.
Also have highway friendly gears, modern power leather bucket seats and Cragar mags.
Thats the one I drive. The others are either waiting their turn, or more modified than not.
I have a Mustang II IFS, diagonal 4-link rear,4 wheel discs,dual servo M/C,power steering and air suspension.
I don't plan any radical body mods other than straightening the old boy out!(Thankfully he's not too lumpy!)
As OldSub mentions,I like them to stop and turn too!
More pix on Flickr.
Between the two trucks, here is a quick list of items done and on the to do:
designed a front crossmember to us GM parts because I didnt want to go Mustang 2 IFS. (done)
Big Block Olds (in process - test fit a few times)
Cummins B33 Diesel (done)
T5 Hybrid (in process)
S-10 frame swap (in process - need to move rear axle back 8")
Custom Box (designed)
Modified '97-2004 S-10 box (to do - sketches done)
Section cab 2.5" (to do)
Big Bolt Fenders possibly with small bolt wheel openings to give a 2" wider fender (in process)
2" wider rear fenders (to purchase)
chopped roof (possibly to do)
4-link rear (to do)
Channeled (possibly to do)
Custom grill (to do)
Frenched antenna (to do)
Custom 1 piece bent front window (to purchase)
Tilt columns in each (in process)
R&P for S-10 frame swap (needed)
Find second revenue stream to pay for it all(still looking)
Other than the Detroit Diesel engine,
Jake brake
Roadranger 10 speed overdrive
Transmission mounted disc parking brake
4" driveshafts with 1610 joints
Dana 70HD rear with disc brakes
ARB air locker and 3.54 gears ready to install
GM I-beam front with disc brakes
Hydrobooster under the floor for the brakes
PS from an IH Scout II
Air helper springs for the rear, soon to have them for the front too
75 gallon aluminum fuel tank outside the frame
Air starter with about 63 gallons of air tanks
Belt driven air compressor
AC compressor (waiting for the rest of the system)
Goose-neck trailer hitch to install, tag along hitch already installed
Still need to install rust free cab
Designing an original style (for late 50's) flat bed and trying to have the rails made of aluminum, then I'll assemble and weld it all together.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
alternator, a/c, ifs, new radio, buick lesabre seats, lowered, s/10 5 sped trans., remote oil filter, dual carbs, fenton headers, offy exhaust manifold, nova rearend, 12 volt. dual exhaust, lokar e-brake handle.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Riding in the Passing Lane
My 70 stepside has 700-4R trans, rear view mirror with temp. & compass, delayed wipers, side turn sig. lights, vintage air-heat, electric fan,95 amp. alt., third brake light,power windows, cargo winch, front disc brakes.
George
1972 Chevy c10 Cheyenne Super
Jake brake
Grigg
Grigg:
Is a jake brake the same as a vacuum release?
~Jim
On my 52, done and to be done. I have most of the parts to complete everything, just need the time
*clifford aluminum 2/4bbl intake with a holley 390 carb (done)
*clifford dual tube style headers, will be going into magniflow mufflers (done and to be done)
*GM 250ci Inline 6 H.E.I. distributor mod (done)
*Tilt/telescoping steering column (have but needs to be installed)
*GM 2wd truck power steering box, mounts to the front on the outside of frame rail (to be done)
*power steering pump mounted to 54 235 inline 6 with custom made brackets (to be done)
*12volt alternator to be moved to passenger side of block next to water pump (to be done)
*new custom wiring, with painless fuse block (almost done)
*autometer 5" sport comp gauges (speedometer and tach) (done)
*autogauge 4 gauge cluster (done)
*swapping out 3/4 ton front axle for 1/2 ton (soon to be done)
*disc brake upgrade (to be done)
*firewall mounted pedal assembly with booster/master cylinder and combination valve (soon to be done)
*battery & mount moved to firewall for easy access (done)
*T5 transmission swap (to be done)
*Nova (i think, 12 bolt GM) rear end (done)
*Rear mounted 16 gallon fuel cell (done)
*Shaved exterior door handles, remote door popper kit (done)
*Bucket seats (done)
*Power windows (needs to be done)
*Shaved firewall (done)
*frenched headlights (needs to be done)
*custom front bed panel....thanks Mickster....(needs to be painted and installed)
*wing windows converted to full pain glass (needs to be done)
*Ultra Blue Pearl paint job (needs to be done)
My 54 truck took me 1500 hours to finish. Aside from the engine machine work and squirting the paint, I did all the work myself.
Aside from the 235 engine which was bored .60, rotationally balanced, machined for fully flow filtering, sporting dual Carter/Webers, Fentons, remote mount oil filter and adaptor plate water pump w/2 groove harmonic balancer:
1. T5 .72 OD 5 speed transmission, Camaro 3.42 open differential, 84 Firebird clutch disc
2. Passenger side alternator mount, 24 circuit wiring system of my own design, with kill switch, halegen headlights and 3” LED tail lights, LED turn signals and bedrail lights, all relay controlled, 15” supplementary pusher fan
3. sway bars, front/rear with gas shocks, front steering stabilizer
4. All new glass (tinted) with slider split rear window
5. Full cab sound/heat proofing
6. Front discs with adjustable proportioning valve for adjusting rear bias inside cab while driving
7. Old Air Conditioning
8. Custom built 1-7/8” ID exhaust to Cherry Bomb glass pack mufflers
9. Star rims, 15x7 on front, 15X8 on rear with BFG 235/70’s front and 255/70’s on rear with 4” backspacing.
10. Upgraded tie rod ends with complete rebuilt front end/steering
11. Bed wood upgraded to “Veranda” synthetic material
12. TonneauMasters modified full soft tonneau cover
13. frame mounted trailer hitch
14. rebuilt/reupholstered stock seat/3 point seat belts/fire extinguisher, seat back modified to tilt forward with storage shelf on top of new gas tank. Fabric covered door & kick panels
15. hood lock
16. AudioVox cruise control
17. Running board aluminum trim plates
18. Engine compartment LED accent lights (8) and LED cab lights (8)
19. Ah-oo-gah horn, New Port Delay electric wiper motor, tach, vacuum gauge, fuel pressure gauge.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Grigg:
Is a jake brake the same as a vacuum release? [/quote]
A Jake brake is a valve that blocks off the exhaust on a deisel engine to give more engine brakeing. It is used on all trucks that drive in the mountains & many other deisel trucks. It causes the loud noise you hear when a truck is slowing down. It gets its name from the original manufactoring co. Jacobs Co. Now many co's make them. Kind of like Band-aid.
Grigg:
Is a Jake brake the same as a vacuum release?
No. A Jacobs Engine Brake is a device that prematurely opens the exhaust valves near TDC on the compression stroke, dumping the compressed air - waisting energy, slowing the truck down.
Or this is how Jacobs describes it:
"When activated, the Jacobs Engine Brake opens the exhaust valves near the top of the compression stroke, releasing the highly compressed air through the exhaust system.
Little energy is returned to the piston, and as the cycle repeats, the energy of the truck’s forward motion is dissipated, and the truck to slow down."
http://www.jakebrake.com/technology/engine.php
About noise:
"FAQ9:
I'm bothered by the noise of big trucks using their Engine Brakes, what can I do?
ANSWER:
The federal government has required all vehicles manufactured since 1978 to meet noise requirements when delivered to the customer. Today, trucks are required to emit less than 80 dBa of noise when they drive by, as measured at 50 feet. So trucks have been required to meet noise requirements when they leave the dealership as new vehicles for quite some time. The real problem here is modified or defective exhaust systems. There is a good chance that the trucks that are causing the disturbance are running with straight stacks or gutted mufflers. Some are poorly maintained vehicles; some drivers simply enjoy making noise. In any case the use of the engine brake is not the problem."
Here's an example of Jake brakes with no muffler:
Grigg
---All pictures---
I guess I missed that I can list planned mods too...
I have a web page that lists each of my project trucks and what I plan to do with it. I just looked and its now fully a year old, so its a little out of date. But if you are interested its at this link.
OldSub.com Current Plan
Maybe I'll take some time this evening and do an update...
planned for my 56 3100...
make her smooth... kinda lumpy now
front disc
power brakes under cab
highway friendly rear gears
vintage a/c
oak bed wood
electric wipers
I know it sounds kinda tame but you ought to see where I am starting...
Brad
my truck is a 49 1/2 ton.it is in no way close to completion.this is work thats either been done or the parts i have in boxes to do.
pacer front end all rebuiltwith new parts
chassis engineering bolt in rear suspension
rci 15 gal fuel cell mounted in rear
lokar nostalgia shifter,trans mounted e-brake,all cables and gas pedal
painless wiring kit
newport engineering wiper kit
master power brakes frame mounted dual cyclinder kit
auto meter pro comp speedo and tach plus gas,temp,oil press,volt
new gre-light tinted glass
12 bolt rear thats been gone thru.
just picked up the rebuilt motor last week(355 sbc) trans is rebuilt also.these are the main improvements i can think of right off.this is not counting boxes of new parts to redo or rebuild everthing else.target date for completion is around 2057 ad. grin i work slow...................dave
ps.forgot to mention the front and rear sway bars
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Oh Geez,where do I start.TCI M2 frontend with power disc brakes and power steering.TCI suspension kit in the rear.Chrome Corvette Ralley wheels,Headers and Flowmaster exhaust system off of the old 350. A built 700R4 trans, and the list goes on.
V
V Offline
My neighbor has a '54 body on a full shorten Toyota pickup. Would that count as "Mods made other than engine mods" for a Chevy truck, or a Toyota truck?
Lets see,
TCI Mustang 11 front end
Camaro 10 bolt rear, 3:73 Posi
4 link rear
new radio
rack and pinon steering
carpet
Lokar shifter
700R4 tranny
Aluminum radiator
Discs front, drums rear
S10 bench seat
gas tank under bed
Cragar mag wheels
Cherry and Purpleheart wood bed
I guess that's It!!
My 1950 truck is back on the road now. after I imported it from the US I took it off the road to do this:
Disc brakes on the front.
Brake booster fitted
Swaybar fitted.
Tremec TKO 500 trans. installed
Saginaw power steering setup fitted
Rewired everything
some of the panels straightened out and resprayed.
I did all the work myself, but looking at this list I can't understand why it took so long to finish, there are probably people on here who do this stuff in a single weekend!
Stuart.
On my 49 sub I moved the gas tank between the frame in back and moved the filler to the drivers side. Weeds
* 327 with TPI
* Narrowed IFS from a '79 1/2 ton
* 700r4 with lokar shifter
* American Auto Wire harness
* Chevy II rearend
* Custom tailgste
* Hydraulic hood hinges
* Taurus hood latch
* Underbed tank
* Torq Thrust II's, 17" rear, 16" front
* Dual exhaust with Flow Masters
* Vintage Air
* Late model buckets
* Electric wipers
* Fire wall mounted power brakes
* Roll pan
Future Plans:
* Seal & smooth cowl vents
* Door Panels
* Radio
* Fiberglass headliner
* Power door locks & windows
* Swan neck mirrors
* Aluminum radiator
Robert C.
I'm a Genius in the making.
1950 3600
there is not one single piece of my truck that has not been modified, from the boxed frame and mustang 2 suspension up front to the TCI leafs anf ford 9 inch in rear with 4 wheel disc to the 5.3 EFI with overdrive trans. custom leather interior, frenched lights, shaved doors and widened rear fender the list goes on. there is not one piece of sheet metal that is not modified about the only thing left stock is the door hinges. I hope to have it on the road this summer
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
OldSub, tell me about your power leather bucket seats???? What kind, new or used, have you made any modifications to make them fit, etc, ???
thanks!
The CPA, never under estimate the value;
especially when he's driving an old Chevy truck!
1947 Chevy 1/2-Ton Advance Design in the Gallery
1951 Chevrolet 3100
My 1955 2nd series, 700r4 trans,TCI M2 frontend,Disc brakes up front drums on rear,with Dual Master cyl power brake setup.TCI rear suspension kit on the rear,which includes new 5 leaf springs mounts shocks and mounts and the rearend has been flipped.Late model S/10 seats 1965 fleetside shortbed,500 cu.in.caddy engine,400 turbo auto trans.57 Chevy rearend. Buick disc brake setup up front,with drums on the rear.Dual MC,no power brake setup. Both trucks are a pleasure to drive and will get out in the passing lane and kick some a$$
2 Offline
My '51 is another one that's not close to being done. I've got a lot of parts and waiting for spring. To cold to work on any thing right now.
327 cid.
Turbo 350
10 bolt posi with new springs
Power disc brakes in front druums in rear
Sway bars
A/C
Elec wipers
Rewire everything 12v
Oak bed with Polished Stainless Steel strips and bolts
Cab and doors chopped 3 "
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one.
-Ralph Waldo Emerson-
So far on my 46 1/2 ton:
12 volt, wiring, and alt set up, T5/short shift block/new 32" shifter, drive shaft, 55' 3:90 3rd memeber, dual Roch 2's, progressive linkage, 4 core radiatior, clutch flex fan, 2" body lift on frame, in the middle of F & R disc brakes and shock swap.
Oh, halogen headlights and blinker indicators in gauge console ; )
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
