7 members (klhansen, 32Fordpuchoptop, FAST55, Jon G, Hotrod Lincoln, 1955 1 Series, Stovebolt48),
109
Mod | | | Forums66 Topics128,120 Posts1,056,319 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48231 07/26/2005 12:14 PM | Joined: Aug 2004 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 56 | Im interested in changing the ring and pinion gears in my '40 GMC. I asked Chevy's of the 40's if their replacement gears would work and they say no, only for Chevy. Has anyone purchased and installed new 3:55 gears for their GMC with success. | | |
#48232 07/26/2005 12:50 PM | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | I'm sure someone will be along to address this but in the meantime, if you do a Stovebolt Google (from the menu bar) for "ring and pinion," you'll see there's a bunch of information on the site -- tech tips and some gallery submissions with similar questions / information / stuff Bolters have done.
Peg
~ One of many.
#48233 07/26/2005 1:13 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Not yet, but I am buying from patricksantiquecars.com. Patrick has what you need for Chevy and GMC.
Mike Barnes 1950 GMC 1-ton pickup
#48234 07/27/2005 6:06 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | There are several people that have used the kit from Patricks and have had good things to say. Kit will run about $900. He's the only one that I know of that handles the conversion kit. Cecil......... | | |
#48235 07/28/2005 5:43 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | guys, i wanna go a bit faster than my 4:10 gears allow too, but is $900 what it's gonna cost me? that sounds like more than a differential could be purchased for. i'm sure i'm missing something here. hopefully someone can fill me in. thanks tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#48236 07/28/2005 1:24 PM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | I have a '45 GMC that has Patrick's 3.55 R&P in it. Unless the price went up dramatically, You should expect to pay $399.00 for the R&P and another $275 for an install kit with new bearings etc et etc. http://www.patricksantiquecars.com/chevyparts.htm Then there's labor for a competent mechanic if you're not up to the challenge. If you put a new axle in, then you need an open driveline, new transmission, new pedal setup, new master cyl, setup the speedo, hack the floor. and on and on. Save yourself the bother Tony and sell the truck to me.  | | |
#48237 07/28/2005 5:06 PM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | k10, i'd feel bad selling you this truck cause it smells like gasoline when you're driving it and it's kinda bumpy when you're going down the road. also, it only goes 50 if you hold it to the floor for a while! did i mention that i have to put a tray under it at night to catch the oil so it don't ruin my garage floor with oil spots? nah, i'm probably the only one who can put up with this kind of treatment so i'll keep her for a while, :-) tony
#48238 07/29/2005 12:55 AM | Joined: Aug 2004 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 56 | Hey thanks to all. I will get in touch with patrich's. G. Lee | | |
