5 members (GMCJammer51, Phak1, Greg_H, WICruiser, tclederman), 93 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#48231 07/26/2005 12:14 PM
Im interested in changing the ring and pinion gears in my '40 GMC. I asked Chevy's of the 40's if their replacement gears would work and they say no, only for Chevy. Has anyone purchased and installed new 3:55 gears for their GMC with success.
#48232 07/26/2005 12:50 PM
I'm sure someone will be along to address this but in the meantime, if you do a Stovebolt Google (from the menu bar) for "ring and pinion," you'll see there's a bunch of information on the site -- tech tips and some gallery submissions with similar questions / information / stuff Bolters have done.
Peg
~ One of many.
#48233 07/26/2005 1:13 PM
Not yet, but I am buying from patricksantiquecars.com. Patrick has what you need for Chevy and GMC.
Mike Barnes
1950 GMC 1-ton pickup
#48234 07/27/2005 6:06 AM
There are several people that have used the kit from Patricks and have had good things to say. Kit will run about $900. He's the only one that I know of that handles the conversion kit. Cecil.........
#48235 07/28/2005 5:43 AM
guys, i wanna go a bit faster than my 4:10 gears allow too, but is $900 what it's gonna cost me? that sounds like more than a differential could be purchased for. i'm sure i'm missing something here. hopefully someone can fill me in.
thanks
tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#48236 07/28/2005 1:24 PM
k10 Offline
I have a '45 GMC that has Patrick's 3.55 R&P in it. Unless the price went up dramatically, You should expect to pay $399.00 for the R&P and another $275 for an install kit with new bearings etc et etc.
http://www.patricksantiquecars.com/chevyparts.htm
Then there's labor for a competent mechanic if you're not up to the challenge.
If you put a new axle in, then you need an open driveline, new transmission, new pedal setup, new master cyl, setup the speedo, hack the floor. and on and on. Save yourself the bother Tony and sell the truck to me. grin
#48237 07/28/2005 5:06 PM
k10, i'd feel bad selling you this truck cause it smells like gasoline when you're driving it and it's kinda bumpy when you're going down the road. also, it only goes 50 if you hold it to the floor for a while! did i mention that i have to put a tray under it at night to catch the oil so it don't ruin my garage floor with oil spots? nah, i'm probably the only one who can put up with this kind of treatment so i'll keep her for a while, :-)
tony
#48238 07/29/2005 12:55 AM
Hey thanks to all. I will get in touch with patrich's. G. Lee
