0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I manage to find a ceramic or porous fuel filter for my glass carter fuel filter assembly ... At least i thought I did ... What I need is for someone who has one on their truck to tell me if the filter fits snuggly in the glass bowl or rattles around inside the bowl ...Some one mentioned somewhere maybe it need a spring to hold it down.. Thanks Peter | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is supposed to be a spring under it that holds it against the gasket on top. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | so when its installed in the carb and the glass bowl face down towards the engine the spring is between the glass bowl and the filter. Wow the spring must be small but broad.. Now where the H... would I get that... Thanks Peter | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Try any run of the mill hardware store. I found one in about 15 minutes going through their boxes of springs. It was a little tall, but a quick snip with the pliers and viola! Perfect fit. | | | | | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | Where were you able to find a filter like that? I ordered a paper filter from Classic Parts but found out the filter was too large.
Neil 1955 Chevy 3200
| | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Millhouse I'll sell you mine for $50.00... I got it at my local shop its from carter, apparently they still make them the # is 30-82.. the one from chevy was probably an ac 124. There was guy on ebay selling the same thing but he wouldn't tell me the #... Peter | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Carter made a compact glass bowl and also a standard glass bowl. Both use different filters and springs.
The paper replacement filter for the standard bowl is..
Purolator F59221 NAPA 3943 Carquest 86943
Carter (revised June 1955) lists the Ceramic filter element for the standard glass bowl, filter #30-60, spring #61-379. compact glass bowl, filter #30-76, spring #61-518
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | The above filters mentioned by Tom are not available at least thats what carters told me!!!! | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Peter,
The paper replacement filters for the standard glass bowl are available. I just purchased the Purolator filter, gasket included, at Advanced Auto for just $2.69.
-Tom
