7 members (Guitplayer, JW51, mo2cyl, Otto Skorzeny, 55shaker, Wally / Montana, 1 invisible), 73 guests, and 3 robots.
Topics128,050
Posts1,055,757
#48119 07/24/2005 12:43 AM
Y
Junior Member
Junior Member
Y Offline
I found these #'s on my block and can't seem to match them to any codes. I am new at this research and probably over looked it. The # is
GCA358038. HELP PLEASE!
#48120 07/25/2005 12:45 AM
Yarb11,
What is it in? I did a little research myself but didn't find anything with the GCA or the #. I have found in the past that some Canadian #s are not listed. You went to Inliners.com right? I'll keep looking.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#48121 07/25/2005 1:21 AM
Y
Junior Member
Junior Member
Y Offline
Thanks, It is a inline 6. I haven't tried that site. I am new and learning as I go. The numbers I listed were toward the front of the block on the right side of the distributor. There suppose be some numbers around the starter. I haven't found those yet. If you run across anything let me know.
#48122 07/25/2005 2:24 AM
X
X Offline
That number looks like the engine serial number. It should have been stamped on a pad just to the rear of the distributor. The GCA prefix is for a '49 216 (built at Flint) that was used in the 4000 series trucks. The rest of the serial number is just the build sequence number.
A '49 216 used in a 3600 or 3800 would have the prefix AGCA or AGCM.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#48123 07/25/2005 12:21 PM
Y
Junior Member
Junior Member
Y Offline
Thanks Xram53. I will check it out when I get off work this evening.
#48124 07/25/2005 11:14 PM
Y
Junior Member
Junior Member
Y Offline
YOU WERE RIGHT. AGCA 358038
#48125 07/26/2005 1:30 AM
Scrape off enough crud above the starter and you should find the casting number. It will be raised letters, and might be behind the starter. Then go to www.inliners.org and look it up. But all it will do is confirm that you have a 216 in the ol gal. wink
Fred
52 3600
69 C-10
