| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48119 07/24/2005 12:43 AM | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | I found these #'s on my block and can't seem to match them to any codes. I am new at this research and probably over looked it. The # is GCA358038. HELP PLEASE! | | |
#48120 07/25/2005 12:45 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Yarb11, What is it in? I did a little research myself but didn't find anything with the GCA or the #. I have found in the past that some Canadian #s are not listed. You went to Inliners.com right? I'll keep looking.
Glenn, | | |
#48121 07/25/2005 1:21 AM | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Thanks, It is a inline 6. I haven't tried that site. I am new and learning as I go. The numbers I listed were toward the front of the block on the right side of the distributor. There suppose be some numbers around the starter. I haven't found those yet. If you run across anything let me know. | | |
#48122 07/25/2005 2:24 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | That number looks like the engine serial number. It should have been stamped on a pad just to the rear of the distributor. The GCA prefix is for a '49 216 (built at Flint) that was used in the 4000 series trucks. The rest of the serial number is just the build sequence number.
A '49 216 used in a 3600 or 3800 would have the prefix AGCA or AGCM.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#48123 07/25/2005 12:21 PM | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Thanks Xram53. I will check it out when I get off work this evening. | | |
#48124 07/25/2005 11:14 PM | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | YOU WERE RIGHT. AGCA 358038 | | |
#48125 07/26/2005 1:30 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Scrape off enough crud above the starter and you should find the casting number. It will be raised letters, and might be behind the starter. Then go to www.inliners.org and look it up. But all it will do is confirm that you have a 216 in the ol gal.
Fred 52 3600 69 C-10
