8 members (HandyAndy, Hotrod Lincoln, baldeagle, Jon G, TexasA&M48Truck, MickeyP, cmayna, 1955 1 Series), 72 guests, and 7 robots.
Topics128,022
Posts1,055,352
Members48,420
#48076 07/22/2005 4:43 PM
As I've mentioned in the last few weeks, my transmission and undercarriage has a lot of 'protective coating' on it. I had planned on taking it to the car wash and removing what I could, then spraying Gunk, waiting, and then doing a second wash. I currently have the access panel (around the floor shifter) removed so I could do a pretty good job.
Question is, this will expose the gaskets etc. more, maybe allowing more contaminants. Since I won't be removing the trans any time soon, whould I be better off just leaving it as-is or should I clean it.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
#48077 07/22/2005 5:31 PM
you might find you need to do more scrapeing than spraying, and makes better use of the Gunk if you scrape the heavy stuff of before you use it - once it's cleaned up you can see if theres any gaskets weeping, but there won't be a problem w/ stuff getting inside - best too if you get that heavy stuff off b4 you get to the carwash, as most take a dim view of plugging their drains w/ 'toxic waste'! grin
