| | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | I've got a '57 roling frame (3200 I believe)that I'm using for a rod project, & have a question about the front drums.
Why are they riveted to the hubs? I've heard not all are, & I'd rather remove the rivets for drum access without bearing removal. I can't see a problem with it.
Also, Are there any off the shelf tie rod sleeves that would let me convert the stock tie rod ends to heim joints, while still retaining the adjustment on the stock drag link.
Thanks for looking. Rick.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can cut the heads off the rivets. They will interfere with many after market wheels. I dont know about the Heim joints but there are replacement tie rod ends that are a modern ball socket design to replace the old style ball & bushing. Put a post in the parts wanted in the Swap meet & i'm sure the fellow bolters will come up with a steering arm. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The drums are riveted from the factory. If a new drum is required the rivets can be ground off and the new drum installed It is not necessary to replace the rivets. The drums are the same front and rear. There are replacement tie rod ends and the connecting rods available from most of the aftermarket suppliers, Brothers, Truck Shop, Carter, etc. I'm not aware of any kits for heim joints. The steering components for 3100 and 3200 series are the same for 55-2 through 59. Fred
| | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | Thanks for the reply guys, much appreciated. | | |
