0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48038 07/21/2005 4:48 AM | Joined: Jul 2005 Posts: 5 Junior Member | | Junior Member Joined: Jul 2005 Posts: 5 | I went down to my NAPA dealer for some sparkplugs for my "new" '54 GMC pickup, (the truck has what I believe to be a 55-57 canadian pontiac 261 with a 235 head and 1 bbl rochester carb) and the closest engine they could find in their catalogues was a 265. Can someone recommend a sparkplug for my setup? thanks alot, mike | | |
#48039 07/21/2005 11:01 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | if it has a 235 head then the 235 plug is what you need | | |
#48040 07/21/2005 2:30 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | AC #45 but it is doubtful that the will have that exact part number so use the R45. The R just stands for Resistor.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#48041 07/21/2005 4:44 PM | Joined: Feb 2005 Posts: 60 Member | | Member Joined: Feb 2005 Posts: 60 | little colder wont hurt at R44s | | |
#48042 07/22/2005 5:05 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I just looked up the application online at Napa. Tell them to look it up as a Chevy with a 235. Any year from 54 to 62 should get there. Only thing is they didn't show any AC Delco plugs, just Champion and Autolite. They should also be able to use the number off one of your plugs and cross-reference. Cross ref for the R45 also shows a Bosch and NGK. Napa counter help outdone by a 53 year old man with a bad heart that doesn't get enough blood to his brain.  Sad, isn't it.
Fred 52 3600 69 C-10
#48043 07/22/2005 10:07 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | rigid6 The NKG number for your application is R5670-5 you can get them at Advance auto parts. You will have to order them by the part number of 2298 as the counter meatheads won't know them any outher way. These are the plugs that most of the racing folks use and they are cheap. I have been told that they are a few mm longer and extend into the head further which gets a better ignition of the mixture. | | |
#48044 07/22/2005 10:25 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | This is kind of a cross reference to another post, but I just called Advance Auto Parts for the NKG plugs that Fat Fenders just referred to...They don't have them, but can get them if I come in before 8:00pm tonight and pay in advance..They are $1.58ea..1.58X6=$9.48...I told them I would go somewhere else..But, they can have them tomorrow..My plugs work perfectly fine..Just wanted to try them out..I don't think the kid has a razor..Take care, Steve | | |
#48045 07/22/2005 10:27 PM | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Everybody knows no self-respecting stovebolt will run with a riceburner plug in it! If your parts man can't find a plug listing for your truck, you need a new parts man. If AC plugs were good enough for it when it was new, they'll work right today. As the number goes lower, the plug's heat range gets cooler. AC 45 is the reccomended plug. If you're doing mostly highway driving, run one step cooler plug, a #44. For one that's run mostly short trips, one step hotter, #46, will help keep the fuel and oil fouling under control.
Thr "R" prefix designates "resistor" plugs, not a bad idea if you, or any of your neighbors has a radio or TV in operation. (It cuts down on radio frequency interference.) Jerry
#48046 07/22/2005 11:18 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Better check the parts you get from our well known suppliers..What's the difference between a plug and a piece of window trim or mirror..By the way, AC stands for Albert Champion..Take care, Steve | | |
#48047 07/23/2005 9:12 AM | Joined: Jul 2005 Posts: 5 Junior Member | | Junior Member Joined: Jul 2005 Posts: 5 | thanks guys that helps me out alot, i appreciate it, later, mike | | |
#48048 07/23/2005 10:09 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | | | |
#48049 07/24/2005 10:31 PM | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | DELPHI (the former AC DELCO) has stoppped manufacturing even numbered plugs. If you go to your parts guy and ask for an AC$44 it will cross to AC45. If you have an old parts store in your area, go see if they have any 44's on the shelf and buy them. A recent check on E-bay for AC44 shows that they are selling for about $40.00 for 8 of them. Also a AC Delco rapid fire #7 is the same as an AC44 (I think, maybe AC45Z I have good luck with them. I do not recommend Champion. As John Sawruk (retired Pontiac enginer) stated at a convention I attended 2 weeks ago. AC DELCO plugs were enginnered for GM vehicles and nothing works better in them.
Just my 2 cents on the topic 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
