1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | I have tried pullers and even the ol' Grease Trick, but the Pilot Bearing has not moved at all. This bearing seems to be brass. Any Suggestions?
1964 c-10
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Run a tap in it, whatever fits and cuts threads, then replace with a bolt of that size and use the bolt to bottom out in the hole and force/jack the busing out.
Grigg | | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | So running the bolt through the pilot bearing wont do anything to the crankshaft?
1964 c-10
| | | | | Joined: Dec 2008 Posts: 13 New Guy | | New Guy Joined: Dec 2008 Posts: 13 | No it wont, however if you want a little bit safer way go to a local hardware store and pick up a thin saw blade, use it to cut through the bearing/bushing and use a pick or screwdriver to bend it up and out. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Nope, won't hurt it at all,
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | I believe a 5/8" standard thread tap works well on the Chevy pilot bushing. It's not really necessary to put a bolt in the hole; just keep cranking on the tap when it bottoms out. The bushing will just walk out of the hole and climb up the tap. Jerry
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Stuff some wet toilet paper into the center and pound it down with something the same diameter as the hole. When it's pounded down some add more toilet paper and pound some more. Worked for me and I got the tip here on Stovebolt.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I take an air chisel & whack it into. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | Thanks for all the help. I had no luck with the toilet paper trick. I think I will try to tap it out for now.
1964 c-10
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Have you checked AutoZone about borrowing a Pilot Bearing Puller & Slide Hammer? Check the diameter of your pilot hole against the minimum diameter of the puller fingers (some fingers cannot be closed enough to fit into the pilot hole). | | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | Yes and the puller fingers would not fit through the bearing. But I rented one from Advance auto Parts, this one spreads the fingers out behind the bearing, and works the same way as a harmonic balancer puller, or steering wheel puller, although this was unsucessful.
1964 c-10
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | You must have one badly stuck bearing. The grease trick has always worked for me. | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I would soak the bearing outer race with PB Blaster for a few 30 minutes to a 1 hour them take a "brass" drift punch and tap the outer race all the way around. Weather its a Brass bushing or a Bearing you could do the same on both as I would replace either one. I hope someone didn't coat the outer surface with RED LOCKTITE! You said you rented a puller was it a slide hammer type? 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | You have to wedge a bolt of something between the fingers of the puller to keep them from slipping out. Scott | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i had oe in a 250 the grease trick failed and i actually broke a pilot bearing puller on a slide hammer. the tap cutting the threads worked like a charm, and it was a lot less effort. that puller threw sparks like flint rock when it came apart!! hr | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have used the grease trick several times and never had it fail to loosen the pilot brg. Just make sure you have a bolt or punch that fits tight in the hole, hit it hard with a BFH and it will move, it's a simple law of physics. Just make sure the cavity in the crankshaft is completely full of wheel bearing grease. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | As a last resort, thread the bushing with a 1/4" or 3/8" pipe thread, and adapt down to a grease fitting with a 1/8" pipe thread. Put the grease gun on it and pump it out. I can't imagine that it wouldn't move with several hundred PSI of grease pressure. Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | As a last resort, thread the bushing with a 1/4" or 3/8" pipe thread, and adapt down to a grease fitting with a 1/8" pipe thread. Put the grease gun on it and pump it out. I can't imagine that it wouldn't move with several hundred PSI of grease pressure. Jerry I hadn't thought of that for this application.. Great idea! But now that you mention it I've seen a tool for just that, a tapered threaded adapter with a grease fitting: http://www.lislecorp.com/tool_detail.cfm?detail=1098 should be able to get it at one of your local auto parts store, or they can order it for you. A normal grease gun puts out 6,000 PSI, and a high pressure one puts out 10,000 PSI. Multiply that by the area you will be acting on, the outside diameter of the bushing. I'll guess it's 1.25" OD or 0.625" R, Area is 3.1415 X R X R. So an area of 1.227 square inches. Multiply that by the pressure, so 7,300 lb for a normal grease gun, or 12,200 lb for a high pressure one. 6 tons should move that bushing right?. Grigg | | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | Ok so last night I decided to give it a few more tries with the grease and it moved about 1/4" and I was thrilled. But then it stopped moving.I kept filling the hole up with grease but it oozes out in between the bearing and the crank. I guess now that it is loose, I will be able to pull with the puller because it should not be that much harder.
Thanks Lance
1964 c-10
| | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Some of the old guy mechamics will fill the hole with grease and find a sutible dowl rod that just fits the inside of the bushing and use a big hammer to compress the grease. It in turn will push the bushing out.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | Finally I had some success. It seems that the object I was using was to small in length. I was using the input shaft on the old tranny because it was a tight fit, although what I could not see is that the pilot bearing was hitting the splines, so no grease was being compressed. I took the new pilot bearing to school today and found a longer bolt that would fit.
Thanks again Lance
1964 c-10
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Lance - Hope you got it out, but if you didn't, the tap works better than anything else I've ever tried and I've tried all of the ways. It also isn't as messy as the grease. Once you get it started, you keep turning the tap and that bearing just backs right out. Good luck! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | in the work i do i have to remove bearing races that have no way to get behind them to drive them out so i have a dremel tool with a flexible shaft on it. use the reinforced cutoff wheels they sell and that bushing will be out in minutes. i have 3 dremels,one with 90 degree attachment,one with flexible attachment and one setup standard. sounds like overkill but when your on the job it really makes a no-fun job bearable not having to switch attachments. | | |
