8 members (Otto Skorzeny, Phak1, TGP, GMCJammer51, DadsFirstPickup, Wayne67vert, carbking, DaveV), 104 guests, and 2 robots.
Topics128,049
Posts1,055,682
#480054 12/08/2008 11:58 PM
Installing disk brake kit on straight axle 52 1/2 ton Chevy. It already has a new manual drum/drum mc with 10/10 residual valves. Drum brakes are working ok, just want more stopping power so am adding disks up front. I think all I need to do is change the front residual to 2 and I'm, good to go? The mc is under the floor in the original location. The company I bought the kit from said I should be good to go with a 2 lb? However I read now that using a drum/drum manual mc with a disk brake will cause the disks to drag? Conflicting information. Thank you in advance.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
I believe master cylinders for discs have a larger reservoir for disc brakes.
some good info on drum brakes, disc brakes and master cylinders
http://www.piratejack.net/Tech-Support/FAQs-Master-Cylinders.html
Can I use my drum brake master for disc brakes?
No, for two reasons. First you will not have enough pressure or volume and second the drum brake master will have a residual valve that will cause the disc brakes to drag.
Drum/drum masters normally have built-in residual valves with equal chambers. You'll need to get a disc/drum master and add a 2 lb to the front and a 10 lb to the rear. A good source for planning your brake system:
http://www.ecihotrodbrakes.com
http://www.MPbrakes.com
http://classicperform.com
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
