| | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Installing disk brake kit on straight axle 52 1/2 ton Chevy. It already has a new manual drum/drum mc with 10/10 residual valves. Drum brakes are working ok, just want more stopping power so am adding disks up front. I think all I need to do is change the front residual to 2 and I'm, good to go? The mc is under the floor in the original location. The company I bought the kit from said I should be good to go with a 2 lb? However I read now that using a drum/drum manual mc with a disk brake will cause the disks to drag? Conflicting information. Thank you in advance.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | I believe master cylinders for discs have a larger reservoir for disc brakes. some good info on drum brakes, disc brakes and master cylinders http://www.piratejack.net/Tech-Support/FAQs-Master-Cylinders.htmlCan I use my drum brake master for disc brakes? No, for two reasons. First you will not have enough pressure or volume and second the drum brake master will have a residual valve that will cause the disc brakes to drag.
