| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#4794 02/14/2002 12:10 AM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | I wondered if anyone had used an S10 rear differetial as a swap and if there were any problems. The width fits well on a swap on the 38 panel. Hey it's finally sunny in Vancouver. | | |
#4795 02/14/2002 11:12 AM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | I have only heard good things about s-10 rearends, I am looking for one now , I went to pick & pull last week to check them out , heres what I got , there 5 ft. wide , and they all seem to have aproxamitly 3.70 gears . All the ones I looked at where 10 bolt, I heard around 1992 or so they went to 9 bolts , there suposed to have larger ring & pinions. Thats I know for now , I will be putting one in my 41 trk. , soon.
Don
#4796 02/14/2002 11:35 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Most S10's with the 4 cylinder have 3.42-3.70 gears.The 2.8's with a 5 speed have 3.42 gears.The later 4.3 models have a slightly larger ring gear, with the most common ratio being 2.73-3.08.The standard ratio depends on if the truck is 2 or 4 wheel or a stick.The 4 wheel drive axle is supposed to be a few inches wider than the 2wd.The rear brakes are small, shouldn't be a problem on a truck that carries no load.The S10 rear will take some abuse but aggressive driving toast a stock rear.One problem occurs on the rear axles, which ride directly on the bearings, like other Chevys.The axles are sometimes worn out , as S10's are entry level stuff that often abused and not serviced properly. | | | | | Joined: Dec 2001 Posts: 146 Member | | Member Joined: Dec 2001 Posts: 146 | The Brazilian built S10 uses a Dana 44 rear end. Cool choice. Although I've heard that the Dana axle is a li'l challenging to rebuilt, I see it as a top unit. And the latter units have a 5X4 3/4 bolt pattern, opposing the earlier ones, with six lugs.(S10 here are new stuff, all the ones produced here just loks likes an Isuzu Hombre, but extended cabs and 4 doors are available).
Alexandre Garcia
| | | | | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | That's good to hear and thanks for the input. I found one from an 88 4x4 with Limited slip posi. It's a 10 bolt and the width is 59". I paid $395 in Canadian dollars. | | | | | Joined: Sep 2001 Posts: 109 Member | | Member Joined: Sep 2001 Posts: 109 | I've always heard good things too, so I went and got one. Now that Im not using it, it sits in the yard waiting for ?????
John Kennedy 1950 Suburban street rod Pics in the Gallery....... new site up! http://home.joimail.com/~kennedyjp/
