2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | I am completely taking the stepside bed of my truck apart to sand it and I cant get the bed sides to seperate from the piece in the back under the tailgate that the tailgate hinges to. I have removed all the bolts that appear to be holding this end piece on. do the sides slide out from the bottom piece or slide up from it?
56 stepside 3/4 ton longbed
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the rear cross sill below the tailgate is welded on
Bill | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | mine is bolted on, the bed pulls up off of the cross sill | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I believe they started welding the cross sill in '51 mid-year to fix a problem with the bed sides shifting in or out at the top over time. My '50 bed has two tack welds there in addition to bolts but I'm not sure if its ever been taken apart or not.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 |
