2 members (dt235sd, 1 invisible), 355 guests, and 4 robots.
Topics128,154
Posts1,057,015
Members48,460
THis might be a dumb question.Im not a mechanic just wondering, what are the chances of installing a 1984 4 speed toyota transmission on my 216 chevy motor. Is it possible?
Anything is possible... it's just metal... Hope you have a machinist or a fabricator for a friend. smile
It may not be to involved, as the Toyota land cruiser folks seem to like the SM465 (a GM 4 speed that easliy fits your engine), so it's possible to go the other way.
Try these folks, either they have an answer or adapter, or should point you in the right direction:
http://www.advanceadapters.com/
What do you hope to gain from this swap?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
What's the point in installing a different 4 speed with the same 1:1 top gear ratio? There are lots of original transmissions available, plus a bunch of full-synchro passenger car 4-speed transmissions like the Muncie or Saginaw if you want to use all 4 gears without double-clutching or coming to a full stop to engage 1st. gear.
Toyota used a 235 in their F45 Land Cruiser,I don't see why you couldn't use that transmission. But like they said anything can be adapted. Hell Dodge put a Viper engine on a motorcycle.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
The engine that Toyota used was not a 235, but rather a copied design. It's dimensions are different from the 235, almost more like GMC, really. Not sure about what bolt pattern was used for te bellhousing, though.
I'm with Jerry, with all of the 4 speds that are a direct bolt up, and even a few 5 speed overdrives that are easily adapted, why use a Toyota trans that really doesn't give much benefit?
Bill Burmeister
do a t-5 s/10 you won't be sorry. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
You can say that again, Ron!
Joe wink
Toyota has a totally bitchin 5 speed that has a really high torque rating, made by aisin. It was used in turbo Supras. That one I can see, for a hot V8, but with a stovebolt six the S10 T-5 seems like the hot ticket. I'm looking for the Supra trans for my '66 chevelle, adavanced adapters make the plate for it. It has like a 450 lbs torque rating, and nice ratios for a hot rod!
Who is John Galt?
