5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
#478907 12/05/2008 9:57 PM
I have a 1944 CCKW 2.5 ton Army truck. The hydrovac appears to be a postwar retrofit. It is almost identical to the hydrovac article available on this website. The one thing the article doesn't mention is the order of the 3 big disks and the leather washer. In his article he didn't disassemble it. I did and forgot to take a picture. Can anyone tell me which order they go back together? Which way does the leather go?
1944 GMC CCKW 6x6 Conversion to German Radio Van
http://716heer.org
rustednuts will have the best information for you; but, here is a 1946-54 diagram that might help.
This is a website I found for my Dodge but they used a hydrovac as well.
http://www.dodgepilothouseclub.org/know/manual/manual.htm
Click on general truck manuals, vacuum brakes, it is a 18meg download with 3 variations on the hydrovac and overhaul sequence.
Ryan
What oil or grease is recommended on these hydrovacs? When I disassembled it, there was a very thick layer of very black, but fresh looking grease, on the cylinder wall on the opposite side of the big spring. Should I apply more grease when I reassemble it?
Neil
http://716heer.org
I can email you a few pictures out the rebuild manual. Shoot me an email an Ill get them off to you. [email protected]
As far as lubricating them, I used mineral oil on mine. You dont want to use anything that has a direct petroleum base. You could also use a thin synthetic, like a corn based oil. Youll want to avoid any thick oils.
Jeff
My 1953 Chevrolet
1947.1 Gallery
I have seen many recommendations that say to use air tool oil.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
