7 members (Otto Skorzeny, Gdads51, VEW, MickeyP, 50Chevy3100, HandyAndy, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,015 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 3 New Guy | | New Guy Joined: Dec 2008 Posts: 3 | I have a 1944 CCKW 2.5 ton Army truck. The hydrovac appears to be a postwar retrofit. It is almost identical to the hydrovac article available on this website. The one thing the article doesn't mention is the order of the 3 big disks and the leather washer. In his article he didn't disassemble it. I did and forgot to take a picture. Can anyone tell me which order they go back together? Which way does the leather go?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | rustednuts will have the best information for you; but, here is a 1946-54 diagram that might help. | | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 59 | This is a website I found for my Dodge but they used a hydrovac as well. http://www.dodgepilothouseclub.org/know/manual/manual.htmClick on general truck manuals, vacuum brakes, it is a 18meg download with 3 variations on the hydrovac and overhaul sequence. Ryan | | | | | Joined: Dec 2008 Posts: 3 New Guy | | New Guy Joined: Dec 2008 Posts: 3 | What oil or grease is recommended on these hydrovacs? When I disassembled it, there was a very thick layer of very black, but fresh looking grease, on the cylinder wall on the opposite side of the big spring. Should I apply more grease when I reassemble it?
Neil | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I can email you a few pictures out the rebuild manual. Shoot me an email an Ill get them off to you. [email protected]As far as lubricating them, I used mineral oil on mine. You dont want to use anything that has a direct petroleum base. You could also use a thin synthetic, like a corn based oil. Youll want to avoid any thick oils. Jeff | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I have seen many recommendations that say to use air tool oil. | | |
