3 members (Bill Hanlon, DES57, Tom McGrath), 118 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#47805 07/18/2005 4:54 PM
We are having a bit of trouble finding parts for our 46 3/4t's carb. It is labelled a Carter W1. I can find listings for it in some of the American catalogs, but I can't seem to find any Canadian based info on it. Any suggestions?
Tempest
"Find Your Inner Truck"
Silly Boys! - Trucks are for Girls!
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
I don't think they sell parts but these guys might have a rebuilt for you. They're in Winnepeg.
http://www.autoline.ca/
Good luck.
Curt B.
You Tube
Riding in the Passing Lane
If you have Carquest or Napa parts stores they should be able to supply you with a kit. I can get the part number if nessesary. smile
1972 Chevy c10 Cheyenne Super
#47808 07/19/2005 12:50 AM
Call Larry Isgro at 516 897-0401. He one of the best carb rebuilders for old carters and Rochesters.
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
"Canadian based info"? NAPA should have parts for it, and prolly could get you a reman unit as well - there aren't many CDN repro parts suppliers, but you might give Scotts Super Trucks in Alberta a call, they might know sources
We have tried at Napa as Mike's brother works there, and we have tried GM Canada as my dad works there... and we have tried at our local Auto Sense dealer... They all have come back with the same thing... Carter W-1 did not exist (At least in Canada). My dad's guy said to get the casting numbers or the tag numbers off of it and he would use those... no numbers... no tags.... Just Carter W-1. The Y or YF carb kit does not fit it.. that is what all the catalogs we have used point to.
Thanks for giving me some direction though
Tempest
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
Tempest - Do a search for carbking, he should have everything you need. As I recall the rebuild kits for the W-1 are more expensive than some of the other carbs, so be prepared.
Hope this helps
George
Carter W1 carbs are plentiful at Swap Meets here in NY as well as exceptional easy to rebuild. They made many different W1's for various applications. The problem with W1's is the bowl covers, some only had 2 screws and the pump was hard to put in.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#47813 07/20/2005 10:08 PM
Anonymous
Unregistered
Anonymous
Unregistered
Give Gary Automotive a call in Edmonton if you still can't find anything. He's got and can get parts dating back to the 30's, only mechanical parts though. Lots of the mechanics and even Napa referred him to me. He can get all the obsolete parts. (780) 439-0399. Good Luck.
