0 members (), 68 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#47802 07/18/2005 4:18 PM
On my 53, 1/2 ton Chevy.If you put 51-54 passenger car hubs on to change your bolt pattern to accept Corvette rally wheels ,do you also need to change the backing plates.Also will these simply bolt into place, or do I have to change the bearings? Anyone,,,,Thanks
#47803 07/18/2005 9:05 PM
I'm 99% sure you need to swap the complete brake assy, backing plates and all. This has been a trick used over the years to get the trucks to 5 lug. Also check out that Corvette wheel for clearance first, may hit the stock tie rods if not other stuff. Seams to me the vette wheels have a very severe 'offset', check it out.
1946 1/2-Ton Chevy
#47804 07/18/2005 9:09 PM
the early car 5 bolt hubs are a direct swap for truck hub up to 59 at least, everything else is the same
