| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | My '41 1/2 ton has a '54 235. On the intake manifold just below the carb there is old "line" that has been closed up with a screwed in brass plug. Looking at pictures of other similar engines, I'm not seeing the same thing. However, when looking at '41 - '46 engines, I see this line running somewhere toward the back part of the block. Is it possible that a PO put an older manifold on a '54 block? What is going on - and more importantly what should I do? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | On the side of the intake should be a threaded hole for vacuum to wiper motor. Maybe that's it???? Look at photos in the gallery or links at other motors. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The only port I'm aware of in that location would be the vacuum port for the wipers, or on later trucks, the HydroVac brake booster.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Only use for vacuum I can think of would be 1. Wipers, 2. Hydrovac or vacuum assist brakes, 3. Vacuum Primer for a fire engine. On my trucks, the tube you're describing is a seperate piece below the carb, basically an insulator with a tube stuck into it, not actually part of the manifold. No reason you can't remove it if it's not being used, though I think you'll need shorter studs for the carberator to bolt to then. Not worth the trouble, in my opinion. Just leave it plugged. Tell people it's the blinker booster!  -Michael | | |
