| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | i went to hook up the heater coil and got confused, it dont take much, anyway at the bottom left side of the firewall is 2 pipes coming through the firewall and at the top is one pipe coming through with 2 pipes coming out the side. thanks for any help | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The "one pipe coming through with 2 pipes coming out the side" is the heater control valve. The supply hose from the thermostat area goes in either one. Run a hose from the other to either of the heater core pipes. Then run another hose from the other heater core pipe to the water pump connection. | | |
