1 members (Wooley), 105 guests, and 0 robots.
Topics128,151
Posts1,056,997
Members48,460
i went to hook up the heater coil and got confused, it dont take much, anyway at the bottom left side of the firewall is 2 pipes coming through the firewall and at the top is one pipe coming through with 2 pipes coming out the side. thanks for any help
1953 Chevy 3/4-Ton Stakebed
[url=http://fiftythree-chevy-flatbed.tripod.com/
The "one pipe coming through with 2 pipes coming out the side" is the heater control valve. The supply hose from the thermostat area goes in either one. Run a hose from the other to either of the heater core pipes. Then run another hose from the other heater core pipe to the water pump connection.
Moderated by  ndkid275, Phak1
