2 members (Bucker, latroca52),
111
Mod | | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | I'm in trouble..... I have a 48 1/2 ton. 350. what have you used? long shaft or short shaft water pump. Lets see what everybody says.....
Tom
48 Chevy 3100 Shortbox 5 window "The Big Dog"
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | I installed a long shaft and my mechanic said there's not enough room between the fan and radiator. The only thing I can figure out is the engine is too far ahead? What do you think?
Tom
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | what is the measurement between your fan an radiator Tommy? with a long pump a spacer and a flex fan Mine sets at roughly 11/16" to 3/4" from the radiator an have had NP's with clearance.....runs good an cool even on a Humid August PA day. Tim
| | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | Is it possible for you to measure from the face of the block to the radiator? I am hoping my long pump works. I have a ton of money in my motor. I purchased a complete march system for a long shaft. Take a look at my pictures on page 7. http://rides.webshots.com/album/549600140EXoKSz?start=0Thanks for helping. Tom
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I'll measure mine also.My rad is a Dodge Aspen.It sits into the original truck rad support,not behind it.I have about 2"clearance from fan to rad. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Tommy, From the face of the block to the radiator in my truck is 11 1/2" Tim | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Tom,the distance on mine is 10 1/2" | | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | Really. I am going to see my truck tommorrow. We will see what we come up with. He is a picture of my engine compartment. Looks like I can move my engine back 2" or so. I would rather do that than replace the march system. http://rides.webshots.com/photo/2377138890089166514fWahoy
| | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | Here's the result from today's visit. I have 8 1/2 inches to 9 inches between the water outlet where the water pump comes in contact and the radiator.
My mechanics plan is to remove the engine and cut the motor mounts off and move them back 2 1/2 inches. Problem solved.
Now I can use my long shaft water pump and march pulleys and brackets.
Thanks to all that helped.
Tom
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Tom ,I had a better chance to measure mine.It is 10 1/2" from the block to the rad.The rad is forward to the grill-hood lock-fender mount thingy.At the rear the firewall is stock.There is about 2" clearance from the left side head [350 Chev] to the firewall.The HEI dizzy also has this clearance to the notch of the firewall | | | | | Joined: Apr 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 54 | FYI, Patrick's sells a short water pump assembly to replace the longer original and keep the radiator and engine in the stock places. I plan on looking into it further so the radiator in my truck can be mounted back to origional. Radiator was mounted to front of support to make room for loner six. | | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | I have about 3" behind my valvecover. were going to make new motor mounts and move the motor back. They started on Saturday.
We will see what happens
Tom
