0 members (), 139 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#474131 11/22/2008 1:48 PM
Apprentice
Apprentice
I have a 1970 c-10 with a 350. I just bouight it and someone added an Gm HEI dist. Does the HEI use differant spark plugs than regular dist. and is the gap differant? Seems though years ago I ran into same problem but forgot. Thanks
Riding in the Passing Lane
The same plugs are fine. You should increase the gap to .045.
1972 Chevy c10 Cheyenne Super
Yes, as Wrenchbender says.
Harvester
And don't use champion in a chevy.
#476797 11/30/2008 2:03 PM
Just curious.........why not Champions?? Never heard that before..........
#476799 11/30/2008 2:19 PM
jdl Offline
Yep, what Joe said. I went to Walmart(yeah, well it wasn't for the truck) to get just TWO sparkplugs for my lawnmower and it called for Champion plugs. Well, I get to Walmart, and every single last one of the plugs hadn't been assembled, or had cracked ceramic, or the list goes on and on. I don't really have anything against the company or their product, it's just that I wouldn't use them in a truck unless I knew the ones I bought were okay.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #476814 11/30/2008 3:01 PM
I used to use champion's in chevy's.they would start to misfire after a couple month's.Needed to replace quite often.I mostly wrote it off as a old wore out motor back then.Was talking o a real chevy man back then and he asked what kind of plug's I was using.(Champion) He say's throw em out and put in A different brand......problem's solved!!!Tom
grub #476836 11/30/2008 4:21 PM
Ive had a lot of trouble with Champions latly also. They break real easy putting them in. 2 of them broke & had nothing in them from the term on the end to the center electrode. I broke another open just to see & all it had was a spring & resister in it.
