0 members (),
130
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 24 Apprentice | | Apprentice Joined: Nov 2006 Posts: 24 | I have a 1970 c-10 with a 350. I just bouight it and someone added an Gm HEI dist. Does the HEI use differant spark plugs than regular dist. and is the gap differant? Seems though years ago I ran into same problem but forgot. Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The same plugs are fine. You should increase the gap to .045. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Yes, as Wrenchbender says.
Harvester | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | And don't use champion in a chevy. | | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | Just curious.........why not Champions?? Never heard that before.......... | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Yep, what Joe said. I went to Walmart(yeah, well it wasn't for the truck) to get just TWO sparkplugs for my lawnmower and it called for Champion plugs. Well, I get to Walmart, and every single last one of the plugs hadn't been assembled, or had cracked ceramic, or the list goes on and on. I don't really have anything against the company or their product, it's just that I wouldn't use them in a truck unless I knew the ones I bought were okay. | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | I used to use champion's in chevy's.they would start to misfire after a couple month's.Needed to replace quite often.I mostly wrote it off as a old wore out motor back then.Was talking o a real chevy man back then and he asked what kind of plug's I was using.(Champion) He say's throw em out and put in A different brand......problem's solved!!!Tom | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ive had a lot of trouble with Champions latly also. They break real easy putting them in. 2 of them broke & had nothing in them from the term on the end to the center electrode. I broke another open just to see & all it had was a spring & resister in it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
