3 members (IHPWR, Phak1, TPR57C),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,877 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47642 07/10/2005 8:53 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | The upper shock mounts for the replacement tube shocks on my 1949 GMC 1/2T p.u. only rise 1" or 1-1/4" above the frame. They came from the catalog as standard. There's about 11-1/2" between the upper and lower mounts. The shortest shock NAPA had wouldn't compress enough to fit, let alone provide travel. What kind of shocks should I be looking for and who carries them?
Never start vast projects with half vast ideas.
#47643 07/13/2005 4:08 AM | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Im not sure if you have some extraordinary situation going on, but I got mine for my 52 from Chevy Duty, They fit fine! | | |
#47644 07/13/2005 7:48 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Maybe I'm missing something, but from what I understand the '49 is a single action lever type shock. Sounds like somewhere along the way someone converted the original type to tube type. Probably because of cost. Cecil....... | | |
#47645 07/13/2005 7:28 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm moving this to Engine and Driveline where you will get more visibilty.
#47646 07/13/2005 8:54 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | Right. I converted from lever action to tube shocks. Simplest thing once I bolted the mounts to the frame and spring shackles was to run over the the local NAPA. Maybe getting the shocks along with the mounts from Chevy Duty or Classic Parts would have been better - may still be - but buying local was not. I always think in terms of buying local. Not to worry, though, This looks like a try till you buy kind of process. Same for the rear shocks, which are 16-1/2" at rest and 10-1/2" compressed. The local AC-Delco store has a set that compress to 10-3/4". Question is if the last 1/4" won't bust the shock's valves. Have to think about that. Thanks for mulling it over with me.
#47647 07/14/2005 5:12 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Retread - Gabriel has a section in their catalog which shows every shock they make from the Red Ryder line, Classic shock line, Fleetline, etc. which shows expanded length, compressed length and type of mount they fit. Each section starts from the shortest shock to the longest shock expanded and compressed. Granted there are not that many choices, but you need to see them all to see which will work. You need the PRINTED catalog to do this comparision - not their computer. Ask them to see the printed catalog and if they don't have one, call the distrubtor or supply warehouse. Good luck! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#47648 07/16/2005 8:54 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I switched from stock levers to tubes on my 46 using shocks, upper and lower brackets off a 52 half ton. Upper mount is positioned forward of the axle to give the shock more travel. You may have some home brew mounts. May want to compare to a stock 51 or later to see exactly how to position your mounts. | | |
