| | | Forums66 Topics128,005 Posts1,055,264 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47618 07/12/2005 8:38 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | I just read a post about narrowed rears and I didn't want to hijack the thread so I am starting a new one.
I am putting a K5 Blazer frame under a 57 Panel.
The track width on the Blazer front end is about 5-1/2 inches wider than the panel would have been originally. I thought about different backset on the rims, but upon closer inspection it doesn't appear to be a viable option. There is only about 1/8" clearance between the stock rims and the tie rod end. Is there another option that I haven't thought of that would be easier than having the axles and tubes shortened? How much extra space between the outside of the tire and the fender was there originally on a Task Force? Maybe 2-1/4" on each side would be OK? | | |
#47619 07/13/2005 1:20 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | bad plan - should find something w/ the right width to start - wheels stickin out looks plain goofy IMO - the TF has 3" from the sidewall of the tire to the outside face of the fender above it - when viewed from straight out front the tire is nearly in line w/ the center line of the lights - if you go w/ the added width you'll be slingin rocks and road crud up the side of the truck glad you ... "haven't done it yet" Bill | | |
#47620 07/13/2005 2:00 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | check the width on a jeep wagoneer the ones wit 6 lug wheels have the same axles as chevy truck/blazer. | | |
