| | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Now, I know that these were found in just about every garage. I see that AirCraft Spruce, and other aircraft supply places, and some tractor places still carry them. Does anyone here have any experiences they can share? I know, plugs are cheap, but so am I. I don't want to run the same plugs for the next twenty years or anything, but I would like to clean them when I change oil and check points etc. Christopher | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Christopher,
I had a CAT gasoline forklift at work that had a bum cylinder. It fouled that plug daily. A small wire brush and some carburetor cleaner allowed me to clean the plug suffeciently to run it again for another day.
When lead was an additive in gas, I have fouled plugs and come hell or high water, have not been able to clean them well enough to fire again.
If you happen to have a small blast cabinet set up with glass beads, you could use it to clean the plugs, otherwise, light oil and soot can easily be taken care of with a wire brush and some type of carburetor or brake cleaner.
Stuart | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | That's interesting. The aircraft guys go on and on about lead fouling. I think though, there consequences are somewhat more severe than mine. I have been brushing them when I replace the plugs, then keep the old set as spares- I don't know why, but I always do. Christopher | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | I had a cheap auto store one years ago did not work worth a %^&#$. Much better luck with a wire wheel on the bench grinder. Dont get agressive, just kinda roll the plug on the very tip of the spinning wire. Brad | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I used to have one in my shop. It worked very well.I cant remember what happened to it,I probably gave it away.It was very useful especially with a lawn mower,a garden tractor,a snowblower,and the kids trail bikes around.It was a lot easier to take the plug out clean it and gap it than it was to run to WalMart for a new one.Now the kids are all growed and gone,and my lawn tractor is a newer one,I probably wouldnt use one. | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Plug cleaner's only clean the visible part of the plug,If carbon or oil/fuel creep's up along side of the electrode,it will short and no longer spark.In a pinch I've heated the electrode end red hot with a propane torch,let cool, and it burnes out the crud along the electrode.Plug will work again for quite awhile.I know,redneck fix but it work's Tom | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Redneck fix or not, it works. I like AC C44 and they are hard to come by, so I clean them with a torch. I would like to say I learned that from Jeff Foxworthy, but I've been doing it for 50 years and I don't think he's that old. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | I do a bunch of work with antique hit and miss engines. I will never again use a blast type cleaner on an antique plug! Champion 34s are a good example. They were originally made specifically for Maytag single cylinder 3/4hp engines. They are 1/2" npt, take apart, dual ground electrode, and no longer available. Years ago, I used a blast type cleaner on several. They ran fine for 15 to 30 minutes and quit firing. when I checked them, they were carbon tracked all the way down the center electrode to ground. On further examination, I found the center insulator to be "rough" from blasting. It had originally been very slick and smooth. I believe that blasting gave the ceramic a texture that made carbon tracking inevitable.
From then on, I clean plugs with carb cleaner and compressed air or a propane torch. Some of these old plugs get pretty pricey, and you do what works and drop what doesn't.
For my money, if I want a spare set of plugs for a car or truck, I'll just buy 'em.
Just my two cents worth.
Best wishes,
Les | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | when my old Vincent motorcycles http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=3196190-R2-050-23A.jpg && http://lsvoc.vincent-hrd.co.uk/images/1950TouringRapide.jpgran in double valve guides and had specialoid pistons running a .006+ cylinder wall clearance and NO valve guide seals, the ignition was 50 degrees and ran on a Lucas magneto, http://www.jampot.co.nz/images_trade_ads/doug_banks.jpg the plugs would always wisker. that fine line arc covered by a film of oil would short the plug out. so i always carried a spare set. mostly it was the rear plug because the 50 defree V and the Lucas mag had the rear as a weaker arc to fire that cylinder. my plugs were newish as i could not get but a couple hundred miles out of them. i cleaned them every week it seamed. they now make very nice pistons and viton valve guide seals. i now run a heavily modified kabota tractor perminate magnet alternator , made one at a time by a machinists/ pipefitter in canada, http://www.iowamotorparts.com/images/KUB-A1-TO.gif to a 60 years old distributer and she fires just fine now.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 36 | I just buy new ones because they never get clean enough with a cleaner. | | |
