6 members (delky, Otto Skorzeny, UtahYork, mason86, Bill Hanlon, Woodcmiami), 54 guests, and 2 robots.
Topics128,030
Posts1,055,424
Members48,422
#474785 11/24/2008 5:05 AM
I recently rebuilt my speedometer for my '53 3100. I put a mechanism from an 80 mph unit in my 90 mph unit because the shaft on my 90 mph unit was broken where the needle attaches. These units are the same whether it's an 80 mph vs. 90 mph...right? I assumed the faces would be the only difference. The numbers on the speedo mechanisms had all the same numbers cast into the housings. The reason I'm asking is because my speedo operates smoothly but it doesn't begin to move until I hit about 10 mph. I have it set at zero. I begins registering when I accelerate to about 10 mph and then routinely reads between 10-15 mph less than my actual speed. Anyone know how to fix this or what's going on? The unit seemed to spin freely at the bench.
1953 3100 | 1958 3/4-ton NAPCO
here in L.A. we have a few speedo shops that specialize in these kind of problems.They dont chargr much and have yet to be stumped by anything I have thrown at them. I know you can obtain correcting gears, but I thought all head units were the same as far as ratio goes. I've had a bunch of speedo's that won't register until 5-10 mph, but they usually are fairly accurate after that.
Who is John Galt?
You could try holding the shaft and moving the needle on the shaft clockwise 15 mph. It sounds like in may have been turned during the rebuild. A hand held GPS comes in handy for finding out which way you need to move things. If the error is off by the same amount through the range just move the needle.
Riding in the Passing Lane
First compare the odometer with the mile markers on the freeway or mark off a mile distance with your car. If the gearing is right then you need to correct the needle like Neilroy says.
1972 Chevy c10 Cheyenne Super
I would send it in to the speedometer shop in Milwaukee, or D&D Speedometer in the twin cities. For low $ they will give it a clean bill of health and have it calibrated properly.
If you screwed with the spring that the needle shaft sits on, in any way, shape or form itll never be accurate. You can blow on these things and tweak them, thats how sensitive they are.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Hey Scott, ya got a name of that speedo shop in Milwaukee?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
