1 members (TrknGMC),
31
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Any bolter know why GM and others did not place a external lock on the drivers side door? To lock the 1946 Chevrolet Truck, you need to twist the “T” lock, and then slide over the seat and exit through the passenger door. What were the engineers thinking? Was it the same thought as suicide doors, thusly being a possible accident waiting to happen due to exiting traffic on the drivers side? When did GM decide to place an external lock on the drivers side? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | so you wouldn't have to get out in traffic, so the story goes. long ago i switched outside handles, put the lock on the drivers side. BTW mines is a 54. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That is correct. In many areas, it was illegal to exit a vehicle on the drivers side when it was parked on the side of a street (take a look at very early cars, most didn't even have a drivers side door). I beleive that a drivers side outside lock became an option when they went to the pushbutton doorhandles in '52. I'm not sure of when it became std equipments, most likely sometime in the early '60s, at least by '67.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | For What it is worth, all the info I have on the 52 trucks is the drivers side door was the same as other earlier years - no external lock - I don't know what year the drivers side door lock was used. Jimmie. | | | | | Joined: Jul 2004 Posts: 2,986 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,986 | I have a '59 F-word truck that still does not have a key lock on the driver's side. I don't think my '58 Binder does either. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | In '52, they changed the handle from the turn style to a pushbutton type, the same handle was used to the '66s. With that handle, the outside lock is part of the handle mechanism, specifically, in the button, than mounted in the door itself. According to the Standard Catalog of Chevy Trucks, the left hand door lock was available, RPO 395. My '55 did not have the external drivers side lock, either, but I added one by swapping out the button.
