3 members (Napco Man, dunfire, 68ironhead), 214 guests, and 2 robots.
Topics128,081
Posts1,055,955
Members48,430
#474219 11/22/2008 7:05 PM
Finally got the barn doors to fit as good as I can get them. Where the doors meet in the center I managed to get the belt lines to match really well but at the outer edges the belt lines are about 1/8th of an inch lower than the belt line on the body. The upper half of the truck is the darker green and the lower half is the lighter green and the separation line is the lower edge of the belt line so I think I can fake it where the two colors separate. You burb guys, do your barn door belt lines match up?
Weeds
Weeds #474277 11/22/2008 9:40 PM
Apprentice
Apprentice
I have a '59 panel and had the same problem. After inventing a total of 16 new cuss words trying to get my doors to line up with each other as well as the body I figured out the secret. The key is to align each door with the body first. Next, either add or subtract shims where the bed floor is bolted to the cross frames at the rear and next to the rear set of bolts. This will actually create a twist which will line the doors up perfectly with each other. It turned out to be so simple that I'm sure thats how the factory probably did it on the line.
DDAUTOPARTS
#474527 11/23/2008 4:32 PM
good tips guys, filed for future reference fitting NOS doors to my project that's had to have major work on the rear opening grin
DD [Pat?] - good to see ya here, you're doing a good thing - bet ya even remember these wink
Flxible #474632 11/23/2008 10:52 PM
Leo Offline
Moderator
Moderator
Yes Bill, but mine are the same length.
