9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman),
93
Mod | | | Forums66 Topics128,069 Posts1,055,886 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Finally got the barn doors to fit as good as I can get them. Where the doors meet in the center I managed to get the belt lines to match really well but at the outer edges the belt lines are about 1/8th of an inch lower than the belt line on the body. The upper half of the truck is the darker green and the lower half is the lighter green and the separation line is the lower edge of the belt line so I think I can fake it where the two colors separate. You burb guys, do your barn door belt lines match up?
Weeds | | | | | Joined: Nov 2008 Posts: 12 Apprentice | | Apprentice Joined: Nov 2008 Posts: 12 | I have a '59 panel and had the same problem. After inventing a total of 16 new cuss words trying to get my doors to line up with each other as well as the body I figured out the secret. The key is to align each door with the body first. Next, either add or subtract shims where the bed floor is bolted to the cross frames at the rear and next to the rear set of bolts. This will actually create a twist which will line the doors up perfectly with each other. It turned out to be so simple that I'm sure thats how the factory probably did it on the line.
DDAUTOPARTS | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | good tips guys, filed for future reference fitting NOS doors to my project that's had to have major work on the rear opening  DD [Pat?] - good to see ya here, you're doing a good thing - bet ya even remember these  Bill | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Yes Bill, but mine are the same length. | | |
