| | | Forums66 Topics128,139 Posts1,056,754 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | I believe that these units are all 4 bolt, but are the Dia. and ring gear the same? | | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | I solved my own problem! The flywheels are all the same Dia. The flat surface is different. The 37 is sort of dished and the 38-39 is flat. A modern clutch, 38,39,40 assembly will not fit on the 37 flywheel. | | |
