0 members (), 149 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
I believe that these units are all 4 bolt, but are the Dia.
and ring gear the same?
I solved my own problem! The flywheels are all the same Dia.
The flat surface is different. The 37 is sort of dished and the 38-39 is flat. A modern clutch, 38,39,40 assembly will not fit on the 37 flywheel.
