6 members (klhansen, Peggy M, Maybellene, TexasJim50, Hanks custodian, Woodcmiami), 92 guests, and 2 robots.
Topics128,059
Posts1,055,820
#47388 07/08/2005 4:35 PM
Junior Member
Junior Member
I have a 54 Chevy 150 with a 235. I'm on my third carb. They all leak! The latest one seems to be leaking at the gasket between the top and bottom. I suspected the float was too high, but when I tok the top off, the fuel level was way lower than the mating surface. This is getting frustrating! I had read about porosity in old over cleaned carbs being a problem and wondered about that. Any ideas?
Also, if I go with a later model carb, what/who is a good route? This is a stock engine and I probably won't go anything more than mild street when I rebuild it someday.
Thanks for the help.
Tony
#47389 07/08/2005 6:14 PM
Try putting 2 gaskets together and adjusting the float level to accomodate the new gasket thickness. It worked for me. The air horn is usually warped on the Rochesters.
#47390 07/08/2005 6:40 PM
Thanks Shipwright...I bought a rebuilt Rochester, runs great, but leaks between the horn and the body..Think I'll do the same..Steve
#47391 07/09/2005 8:26 PM
I went through 2 rebuilts before I bough a new one through NAPA believe it or not. By the way it didn't cost much more than a rebuild, and was properly adjusted....just bolted it on and fired it up.
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver
1929 **** Model A Pickup - Restoration
#47392 07/09/2005 9:30 PM
Carbking has a fix for the airhorn warpage on the Rochester B. Click here
Fred
52 3600
69 C-10
#47393 07/10/2005 5:15 AM
FYI. I tried carb kings fix for the warpage problem and ruined an air horn. I don't think I got it hot enough. My bad, not his advice. If you do try it just be careful is all.
