| | | Forums66 Topics128,069 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47388 07/08/2005 4:35 PM | Joined: Jul 2005 Posts: 1 Junior Member | | Junior Member Joined: Jul 2005 Posts: 1 | I have a 54 Chevy 150 with a 235. I'm on my third carb. They all leak! The latest one seems to be leaking at the gasket between the top and bottom. I suspected the float was too high, but when I tok the top off, the fuel level was way lower than the mating surface. This is getting frustrating! I had read about porosity in old over cleaned carbs being a problem and wondered about that. Any ideas?
Also, if I go with a later model carb, what/who is a good route? This is a stock engine and I probably won't go anything more than mild street when I rebuild it someday.
Thanks for the help.
Tony | | |
#47389 07/08/2005 6:14 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Try putting 2 gaskets together and adjusting the float level to accomodate the new gasket thickness. It worked for me. The air horn is usually warped on the Rochesters. | | |
#47390 07/08/2005 6:40 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks Shipwright...I bought a rebuilt Rochester, runs great, but leaks between the horn and the body..Think I'll do the same..Steve | | |
#47391 07/09/2005 8:26 PM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | I went through 2 rebuilts before I bough a new one through NAPA believe it or not. By the way it didn't cost much more than a rebuild, and was properly adjusted....just bolted it on and fired it up.
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
#47392 07/09/2005 9:30 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Carbking has a fix for the airhorn warpage on the Rochester B. Click here
Fred 52 3600 69 C-10
#47393 07/10/2005 5:15 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | FYI. I tried carb kings fix for the warpage problem and ruined an air horn. I don't think I got it hot enough. My bad, not his advice. If you do try it just be careful is all. | | |
