2 members (tclederman, Phak1),
37
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | I am in the process of doing a complete off the frame restoration of a 1935 chevy 1\2 ton pickup. This truck was built sometime after May of 1935. It has the high cab and hydraulic brakes. The 207 engine was not repairable but I was able to get a good 216 that I have rebuilt. The problem is the bell housing from the 207 does not match the holes on the 216. Easy fix, use the bell housing from the 207! That would be good except anyone who has a 35 or 36 knows that the brake and clutch peddle assembly plus the master cylinder shelf all mount to the side of the bell housing. Has anyone done this conversion? Could really use some ideas.
Charlie | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I cant help but Id love to see some pics of the old gal!
Jeff | | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | Nothing much to see. I have finished the frame and rear end, brakes and hydraulics. Next I wanted to set the engine but this is a bi problem and I don't know what to do? Thanks for the interest | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Is this link any help? https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Board=1&Number=392011&Searchpage=1&Main=52483&Words=%2Bbuffalo+%2Bhousing&topic=0&Search=true#Post392011
There are quite a few posts that may be of use to you. Do a search for " +buffalo +housing " in the Engine and Driveline forum. | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | The 1941 bell housing also has the mount for the pedal assy. and uses a 216 engine. Hope that helps.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | Thanks for your help, What I really need to do is find a bell housing from a 37,38,39 truck because the 216 engine bell housing has a different hole pattern the the 207. What I have decided to do is change to a 38 housing and clutch. that way I get rid of the week throwout bearing and have something that is easier to adjust. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | When you find that bell housing you will need the cross member out of a 37 or later frame to make the swap easier. I put a '41 216 engine and tranny in a 1933 truck and this worked for me. You will also need to make a plate to support the front engine mount as the 216 is a shorter engine then the 207. Good luck, Cleon | | |
