4 members (TUTS 59, 55shaker, Wrenchman, Oswald), 55 guests, and 1 robot.
Topics128,089
Posts1,056,010
Members48,430
#472696 11/18/2008 11:06 PM
I am in the process of doing a complete off the frame restoration
of a 1935 chevy 1\2 ton pickup. This truck was built sometime after May of 1935. It has the high cab and hydraulic brakes. The 207 engine was not repairable but I was able to get a good 216 that I have rebuilt. The problem is the bell housing from the 207
does not match the holes on the 216. Easy fix, use the bell housing from the 207! That would be good except anyone who has a 35 or 36 knows that the brake and clutch peddle assembly plus the master cylinder shelf all mount to the side of the bell housing.
Has anyone done this conversion? Could really use some ideas.
Charlie
I cant help but Id love to see some pics of the old gal!
Jeff
My 1953 Chevrolet
1947.1 Gallery
Nothing much to see. I have finished the frame and rear end, brakes and hydraulics. Next I wanted to set the engine but this is a bi problem and I don't know what to do? Thanks for the interest
Is this link any help?
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Board=1&Number=392011&Searchpage=1&Main=52483&Words=%2Bbuffalo+%2Bhousing&topic=0&Search=true#Post392011
There are quite a few posts that may be of use to you. Do a search for " +buffalo +housing " in the Engine and Driveline forum.
1951 1 Ton Completed
The 1941 bell housing also has the mount for the pedal assy. and uses a 216 engine. Hope that helps.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
Thanks for your help, What I really need to do is find a bell housing from a 37,38,39 truck because the 216 engine bell housing has a different hole pattern the the 207. What I have decided to do is change to a 38 housing and clutch. that way I get rid of the week throwout bearing and have something that is easier to adjust.
When you find that bell housing you will need the cross member out of a 37 or later frame to make the swap easier.
I put a '41 216 engine and tranny in a 1933 truck and this worked for me. You will also need to make a plate to support the front engine mount as the 216 is a shorter engine then the 207.
Good luck, Cleon
1949 Chevy 6400
1931 Chevy Firetruck
