3 members (Hotrod Lincoln, Otto Skorzeny, Peggy M), 98 guests, and 3 robots.
Topics128,026
Posts1,055,409
Members48,422
#472703 11/18/2008 11:29 PM
is there anyway to test a temp gauge?
rusty52stovey #472714 11/18/2008 11:44 PM
run the truck and use the wifes candy or meat thermometer in the rad to compare - or if the truck isn't running, dunk the sender in boiling water and watch the gauge, use the thermometer to compare gauge reading to water temp as it cools
rusty52stovey #472723 11/18/2008 11:56 PM
Yes, at the dealer I work for we have a device that checks the guage using veriable resistence. You hook up the device to ground and to the wire at the sending unit and turn the knob. This causes a resistence that changes as you turn the knob.
When the knob is at its lowest setting the guage reads cold, middle setting reads normal, and highest setting reads hot.
So with that in mind ground the wire st the sending unit (with the key on) and see if the guage moves to hot.
Ya know I wrote all this and it occured to me that you may have a mechanical guage. If so, boil a cup of water in the microwave drop in a thermomature when the temp gets down to 190 drop the sending unit bulb into the water and watch the guage.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
Toyvo #472730 11/19/2008 12:02 AM
I'll bet his '52 Stovey does have a mechanical temp gauge....with no vibrator either. wave thumbs_up wave
Stuart
atomarc #472831 11/19/2008 3:53 AM
anybody know why in a pot of boiling water my gauge didn't move at all? is the spring that expands shot?
That spring is actually a Bourdon tube which is part of a sealed system that makes the needle move. If it has sprung a leak it's not going to work until it's professionally rebuilt or replaced with a new gauge and tube (one piece). That's how I see the situation.
Stuart
atomarc #473006 11/19/2008 4:52 PM
LOL Stuart, Ain't a going there.
Toyvo #473014 11/19/2008 5:23 PM
Rusty, I sent you a pm....hope it helps.
