| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47257 07/05/2005 4:45 AM | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | My 235 runs really ruff. I don't like the sound. It's hard to keep it running. The distributor is shaking constantly. If I hold the distributor from shaking & turn it a bit...it runs a little better, but still not good enough to drive...
What should I check??? | | |
#47258 07/05/2005 5:27 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | G'day mate,
Was it running ok before and if so what have you done since then. You said if you hold the distributor and turn it a bit that it runs a bit better. If you are able to turn the distributor with the engine running ( over the normal movement for the vacuum advance )the lock bolt on the back of the distributor may be loose. You should start by setting the ignition timing and see if that makes a difference and then work from there. Do you have a workshop manual?
Cheers
Bob | | |
#47259 07/05/2005 12:23 PM | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | Bob:
The distributor is secure. Timing hasn't changed since it was running good. The movement I refer to is the small vacuum advance amount. The only thing I've done is file the points (while in the distributor) & change the spark plugs. All this was after the ruff, chugging idle started.
I think I'll pull all my plugs & the valve cover & hand turn the motor to see if I have a stuck valve. | | |
#47260 07/05/2005 2:53 PM | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | Check your Cap and Rotor and also Check your Wires. My guess is that one of these is bad or all of them.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#47261 07/05/2005 3:24 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | or if you had removed the wires one now may be crossed wire,,,,I have never done that  but some have,,,,,,,,,,,,,,,,,,,,Fred Just drive em.................... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#47262 07/05/2005 4:01 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I just did what Joker said. :o Regapped my plugs for the pertronix and crossed the #2 & #4 wires. They are about the same length. I thought it would be obvious when putting the wires back on. I was wrong. Hope it's as simple as that. | | |
#47263 07/05/2005 8:17 PM | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | Here is the firing order if you need it
1 5 3 6 2 4
15 Too Young 36 Too Old (don't tell my wife I said that) 24 Just Right
Good luck
#47264 07/05/2005 11:04 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Check the condition of the vacuum line between the distributor and the carb. Mine ran rough and no matter what I did it would not smooth out until I found a crack in the flare of the vacuum line. | | |
#47265 07/06/2005 12:51 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Has it been sitting long between when it ran ok and now? Check everything that the guys have mentioned plus maybe the condensor. If its been sitting a long time could it be bad fuel? | | |
#47266 07/06/2005 3:43 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | Could be loose motor mounts... | | |
#47267 07/06/2005 5:11 AM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | If all you did was to clean up the points with the distributer in place then I would guess the gap is not set right on the points or possibly they are bent which would make the gap wrong too. I would first check the gap and if that doesn't do it then replace points, condenser and maybe the cap. suppose the wires could have gotten pulled loose or broken inside, especially if they are the radio suppressent kind. You can often tell if a plug isn't working if you get it running and pull one wire at at time, replace it and try another. If you pull one and not much is noticabe that's the culprit.
40 Chevy 1/2 ton
#47268 07/06/2005 12:31 PM | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | Hey everyone:
I want to thank everyone for your replies... I've found a stuck valve...never had one before...& now I'm trying to figure out how to fix it. This board is great!!! Thanks again!!!
Carl | | |
