Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Bill Marlow, Otto Skorzeny, baldeagle, EchoBravoSierra, Jon G, Jeff Ogden), 38 guests, and 3 robots.
Topics128,005
Posts1,055,266
Members48,418
#472149 11/17/2008 6:52 PM
My truck is painted classic white with a pearl clear overcoat and another clear coat over that. The exhaust yellows the paint on the tailgate. I can't rub it out, only by using600-1000 wet papet can I get it out 2 coats of wax. I have tried everything. help
gazim #472199 11/17/2008 9:24 PM
yer problrrm is them tips that barely peek straight out - should be angled down and outward, to keep the exhaust from swirling back up against the gate .... but that wouldn't look so cool eh? grin better than the grass skirts on the back of RVs tho!!
Flxible #472563 11/18/2008 3:05 PM
Well Bill, you are supposed to come up with a solution. I need help here.
gazim #472567 11/18/2008 3:16 PM
Gazim,
without looking it sounds like the clear coat is getting a good dose of fumes/unburnt fuel circling back against the tailgate and is discoloring your clear coat.
I would guess rerouting your exhaust tips will be the only cure ...sanding an waxin is gonna leave ya with a dead paint really soon (CLEAR COAT GONE).
maybe flaring the tips more out to the side to catch the free flowing air as ya drive may be an option or double check your Carbs mix and motor timing to get a cleaner burn ?
Tim
1952 Chevy Shortbed
Photos in Photobucket
gazim #472569 11/18/2008 3:29 PM
the solution is prevention - move the exit point of the pipes, like just behind the tires, pointing out and back, get the exhaust away from the airflow that comes under the truck .... solution to fixing the paint damage? repaint ohwell
if it was a panel truck you'd be getting fumes inside, most unpleasant
Flxible #472903 11/19/2008 6:12 AM
Gazim, As other have said, go to the source causing the problem, redirect the exhaust...Hopefully, You can hit the tailgate
with ultra-fine to wet sand Your problem out...As Bill said, if You
break through the clear than its repaint for sure...
There is NO strength in clear, and that is exactly why I always put color into My clear which gives it the ability to
cross-link...I am also talking lacquer color and clear...We had problems at GM with the white Corvettes, the clear would yellow, and it wasn't the exhaust because the whole car yellowed...The new
color coat and clear coat used today eliminated those problems...
Bill B.
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
