| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 65 | Hey all, my 1950 152 (3/4 ton) needs new front wheel bearings, and I thought while I was at it, I might as well upgrade to the newer roller bearing type for better handling and longer life. I can find them for 1/2 tons all over the place, but not for 3/4 ton. Any suggestions?
Cory | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The tapered bearings wont last any longer or handle any differently then the ball type, so long as they are adjusted properly.
As for numbers, I cant help.
Jeff | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Grab a Federal-Mogul master bearing catalog and a dial caliper, and start measuring! Chances are you'll be able to find something that will swap out. Jerry
| | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 65 | Thanks Guys,
I was hoping someone had a link to some specialty shop that sold them, but like most things worth doing, it isn't always that easy. Now...off to find a Federal-Mogul master bearing catalog.
Cory | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | This is all I have. Some of it may or may noy not pertain t you, this is just a collection of information that I have gathered over time. I hope something here helps. If nothing here works for you you might try asking Denny Graham. He has a 3/4 ton and might have the info you need.
New Departure Front Inner Bearing #s 1946-1953 passenger car and 1/2 ton truck, 1941-1942 passenger & commercial 909552 Outer Race 909602 Inner Race 909702 Inner Bearing
1946-1953 Passenger and 1/2 ton, 1929-1930 All, 1931-1942 Passenger & Commercial (exc. CC, DC, EC, FC Models) 909501 Inner Race 909601 Outer Race 909701 Outer Bearing
Wheel Seal Original #s for the Inners for 1946-1953 Passenger and 1/2 ton trucks with Felt seals and Retainers; GM part # 3656536
Not sure where I got these numbers or what they represent. Inner: 909052R Outer: 909067R Seal: National 6064
