0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I'm still having problems on my late 235 with a fenton duel intake. It has 2 holly single barrel carbs and when i step on the throttle rapidly it almost dies. The intake has a heater on it as suggested, but problem still persists. I wonder if the fuel pump is the problem I have the one with a glass bowl on it. Maybe it doesn't put out enough fuel for 2 carbs. Cecil....... | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Cecil,
The stock pump is more than adequate, even for three carburetors. I'll guess your problem is a tuning/timing issue or much more probable, a carburetor issue proper.
Remember, when you stomp the throttle, you are working off of fuel in the bowls themselves...the pump just has to keep them full, which is pretty easy. That's my thought.
Stuart | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Yeah, what Atomarc said. I think the most common problem with fuel pumps, other than the originals, is too much flow rather than too little.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | I found this page helpful. Specifically, the top two subjects. I also have a hesitation from idle, if I stomp on the pedal (not in gear) it bogs, and will stall unless I let up. I'm running a holly/weber from langdon's. I'm messing around with tuning/timing using a tach/dwell meter, timing light and vac guage. No luck yet, though!
