I found
this page helpful. Specifically, the top two subjects.
I also have a hesitation from idle, if I stomp on the pedal (not in gear) it bogs, and will stall unless I let up.
I'm running a holly/weber from langdon's.
I'm messing around with tuning/timing using a tach/dwell meter, timing light and vac guage. No luck yet, though!
