9 members (Wally / Montana, padresag, walter74, Wayne67vert, Shaffer's1950, treegrower, TexasFarmTruck, Otto Skorzeny, 1 invisible),
75
Mod | | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 41 | My 39 has remnants of wooden body mount blocks,is this stock ? If so, can they be purchased and where? If not,has anyone have dimensions etc. to make them ? Any help greatly appreciated.Thanks
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Sooner, try this it may help get you on the right track. http://www.oldchevytrucks.biz/34_46/full.asp?page=0019This link it for the truck but you may find them for panel as well. I just finished making my mounting blocks for my 52 Panel and they are wood. On mine there is also a rubber pad that goes on the bottom between the wood body mount block and the chassis. I also would suggest going to the forum (bed forum) where Mar-K is listed as they sell bed/wood kits. You may find something of value there. Good luck and perhaps someone working on your model will come along shortly. | | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Good Evening Sooner, Jim Carter should have a set. I sent him an old set from my '46 Suburban for patterns. I believe they should fit from 37 or so up through early '47 Panels and Suburbans. Good Luck hope this helps. Richard
Richard J Patrick - 1946 Suburban
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | The link I left for him is actually the page showing some body mounts from JimCarter. However, Sooner, if you can find the dimensions you can make your own and for the rubber part between body and frame I use some old firehose pieces. A volunteer fire dept gave me quite a piece of old hose and it really works nicely. Theres other things to use as well but after all the work I noticed the price of a NEW set was really not that bad....but maybe the price plus shipping to where your at would run the price up to where you would wantg to make them... | | |
