4 members (Gdads51, Otto Skorzeny, 2 invisible),
113
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | needing advice on welding in a repair patch on a frame at a cross member behind the cab and also where the rear spring bracket attaches to the frame it looks fairly deteriated around the bracket and has a couple holes about the size of a quarter also can you replace the rivets with grade 8 bolts thank you
| | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | Yes, you can replace the rivets with grade 8 bolts.
To give you good advice on welding in a patch to a frame, we need a little more information. How big an area, how badly rusted the section and which crossmember?
1949 "Heinz 57"
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Frames were not heat treated so they can be welded if there is enough still there to weld to. Sometimes they are so rusty that all you do is burn holes. | | |
