2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#470736 11/13/2008 12:37 AM
needing advice on welding in a repair patch on a frame at a cross member behind the cab and also where the rear spring bracket attaches to the frame it looks fairly deteriated around the bracket and has a couple holes about the size of a quarter also can you replace the rivets with grade 8 bolts thank you
Yes, you can replace the rivets with grade 8 bolts.
To give you good advice on welding in a patch to a frame, we need a little more information. How big an area, how badly rusted the section and which crossmember?
1949 "Heinz 57"
Frames were not heat treated so they can be welded if there is enough still there to weld to. Sometimes they are so rusty that all you do is burn holes.
