| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 8 New Guy | | New Guy Joined: Nov 2008 Posts: 8 | I accidentally scratched one of my new main bearings. It goes across the bearing about 7/16" and seems "deep". Is there a way to fix it? What will happen if I try to use it? | | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | Are they poured babbet bearings or inserts?
If they are babbet bearings, it can be fixed, but you have to find someone that still does that kind of work near you.
If they are inserts, a new set of main bearings is a small price to pay for piece of mind. There is no way to repair it, so if it were me, I'd replace it.
There is one thing a scratch in a bearing is good at, and that is collecting debris. And a little debris can do a lot of damage quick.
1949 "Heinz 57"
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Probably nothing would happen if you used it, but you would always worry about it. These old timers are for fun and a sense of satisfaction. Anything that you might worry about later, fix it. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 46farmtruck,
Think of the scratch as a extra oil groove you put in yourself. If you remove any material that sticks UP then the bearing will be fine...in my unprofessional opinion.
Stuart | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I agree with Atomarc. That was a great explanation too! Somehow I think that he like I have been through this at one time! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would like to see it before giving advice. Got a picture? Scott | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | just make sure theres no high spots they used to have bearing scrapers but you can use a razer knife to cut the high spots doun on the bearing if there is any | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | i have one! It's called a babbit bearing knife. It looks like a triangle from the top, with three sharp edges running to the handle like a three way knife. I use it to open up braided hoses to ease slipping over hose bungs. I asked on old timer at a shop Iworked at and he told me the name. He said it was used originally for shaving a babbit bearing to achieve proper clearance.
Who is John Galt?
