2 members (dt235sd, J Lucas), 85 guests, and 1 robot.
Topics128,102
Posts1,056,532
Members48,448
I am working on a stock 235 w/std 3 speed.
Does anyone know the torq values for the 6 mounting bolts attaching the pressure plate assembly to the flywheel?
Also the Chevy Shop manual lists a torq of 70-75 ft lbs for the 5 speed trans to bell housing bolts but nothing for the 3 or 4 speeds. Does anyone know what the torq should be for the 3 speed mounting bolts?
thanks,
Bob
JD,
back in the day of rollin in the dirt wrenchin, for a pressure pate I went with tighter than heck an 2 more turns !..lol.. never had one get loose ..but Im sure someone will chime in with what the service manual says is correct.
for the trans i would guess the same tourqe value for the 5 speed would be just fine for the 3 speed 75lbs sounds bought rite.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Bob,
Here are the values
Torque specs are:
main cap bolts 100-110
bellhousing bolts 45-55
flywheel bolts 50-65
rod nuts 35-45
oil pan corner bolts 12-15
oil pan bolts 6-7
clutch pressure plate bolts 25-30
cylinder head bolts 90-95
manifold clamp bolts 15-20
manifold end clamp bolts 25-30
water pump bolts 25-30
spark plugs 20-25
fuel pump bolts 15-20
rocker shaft bolts 25-30
Ganesh
