| | | Forums66 Topics128,095 Posts1,056,494 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 99 | I am working on a stock 235 w/std 3 speed.
Does anyone know the torq values for the 6 mounting bolts attaching the pressure plate assembly to the flywheel?
Also the Chevy Shop manual lists a torq of 70-75 ft lbs for the 5 speed trans to bell housing bolts but nothing for the 3 or 4 speeds. Does anyone know what the torq should be for the 3 speed mounting bolts?
thanks,
Bob | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | JD, back in the day of rollin in the dirt wrenchin, for a pressure pate I went with tighter than heck an 2 more turns !..lol.. never had one get loose ..but Im sure someone will chime in with what the service manual says is correct. for the trans i would guess the same tourqe value for the 5 speed would be just fine for the 3 speed 75lbs sounds bought rite. Tim | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Bob,
Here are the values
Torque specs are:
main cap bolts 100-110 bellhousing bolts 45-55 flywheel bolts 50-65 rod nuts 35-45 oil pan corner bolts 12-15 oil pan bolts 6-7 clutch pressure plate bolts 25-30 cylinder head bolts 90-95 manifold clamp bolts 15-20 manifold end clamp bolts 25-30 water pump bolts 25-30 spark plugs 20-25 fuel pump bolts 15-20 rocker shaft bolts 25-30
Ganesh | | |
